Cat 3.1 control panel and driver problem please help
Discussion in 'Desktop & Laptop Computers Forum' started by fatrich, Feb 24, 2003.
  1. fatrich
    fatrich
    Jun 21, 2001
    2,492
    halifax
    +31
    Cat 3.1 driver and control Panel problem
    Can anyone please help me, i have just updated the tt to the new .23 patch and the ffd show and every thing is just fine.My problem is that i have been using the Ati 3.0 cat driver and control panel, so i uninstalled both the panel and the driver last night (no issues) then installed the new driver 3.1 (no problem) and then the control panel 3.1 (again no problems) then i set the resolution (via the latest version of powerstrip) and then this is when i new i had a problem, i wanted to chang the overlay in the control panel, so i pressed settings>advanced the screen flickered a few times and nothing happened so i waited a minute or so pressed it again still nothing so i went to x out and i got an error report saying it could not access it.
    I uninstalled the driver and control panel and installed them again still the same.So i downloaded the driver and panel again installed and still it hangs.
    Anyone got any ideas please?
    By the way the 3.0 cat driver and panel im using at present when i go in to the control panel and press advanced i still get a screen flicker and after about 5 to 10 seconds it lets me in to the control panel
    thanks in advance
    richard
    Report
  2. Kramer
    Kramer
    Did you also upgrade to DX9?
    The Cat 3.1s are DX9 drivers, so you should have DX9 installed before running them.
    Just a thought.
    BTW, there is a link to DX9 on ATI's download page (in the Cat 3.1 page). Has to be done on-line though :mad:
    Best of luck :smashin:
  3. fatrich
    fatrich
    Jun 21, 2001
    2,492
    halifax
    +31
    Problem fixed
    I simply deleted the driver and panel and all the files that could be deleted, went in to regedit and pulled all the ati video listings.Now both the 3.1 driver and panel work ok, even though it was 1am when i finished.
    Now at last i can do some testing
    cheers
    richard
  4. Steve Bate
    Steve Bate
    Nov 10, 2002
    680
    Tarporley
    +11
    Rich,
    Is it worth going to DX9 & Cat 3.1 or stay with DX8.1 and Cat 2.5?
    Steve
