Castle Richmond 3i speakers
Discussion in 'Home Cinema Speakers' started by dej23, Aug 22, 2005.
  1. dej23
    dej23
    Dec 8, 2003
    2,790
    68
    +85
    Does anyone have any feedback regarding these speakers, and where would the best place be to purchase a pair?
    Dej
  2. HTdude12
    HTdude12
    Yes, I have auditioned these...
    They through a wide soundstage with a wonderful midband and delicate highs; bass is rather small but is tight and accurate.
    A great all-arounder indeed!
  3. CJROSS
    CJROSS
    Nov 16, 2000
    5,070
    +343
    Wonderful paired with a £500 sub, not much Ive heard below £1000 to touch them.
  4. dej23
    dej23
    Dec 8, 2003
    2,790
    68
    +85
    Cheers for the input
    Dej
  5. Markie Boy
    Markie Boy
    Dec 13, 2002
    1,256
    63
    Perth, Western Australia (Originally Ireland)
    +227
    Totally agree with this comment. Finish and build quality is exquisite, as is the the soundstage, both in width and depth. Position as close as you can to wall for increased bass (which will not be bags full anyway).
  6. cribeiro
    cribeiro
    Nov 2, 2002
    2,797
    A Spaniard in Germany
    +307
    I own a pair, and auditioned several others. Face to face against dynaudio audience 42, which are near 50% more expensive, they only lost in the bass depth department (depth, not quality!). But I do not think they are so light-bass, and what they deliver is very well tuned. Just missing the extra "grunt" sometimes, which I can get via my subwoofer. This adds a bit of ambience with music (unless you listen to stuff with really deep bass), and the entertainment factor with movies. They are great for the price anyway.
    When I place them near the wall, the bass sounds artificially enhanced, and the "sound image" is flat. Step by step (and leaving them for days at different distances), I ended up placing them about 60 cm away until the image was good and the bass balanced. But room acoustics is tricky, and it will be different for you.
    Of course, their finish is a BIG plus.
    Best regards,
    Alberto
