Casino Royale Deluxe: annoying stick label
Discussion in 'Blu-ray & DVD discs' started by turbohat, Feb 5, 2009.
  1. turbohat
    turbohat
    Nov 7, 2004
    330
    +3
    tried to gently peel the oval "play on ps3" etc label from the front. Once I started I had to carry on. Annoyingly it's really stuck to the matt cover. Lot's of sticky still there and I don't want to use a solvent as it would soack into the case.
    The normally reliable baby wipe faile me:-(
    Damn annoying labdl, why isn't it on the outside of the cellophane?
  2. y2k
    y2k
    Jan 3, 2008
    3,300
    Banana Republic
    +291
    Try washing up liquid.
  3. nigel2shady
    nigel2shady
    Jun 4, 2006
    734
    +9
    I bought this Deluxe edition last week,first off looks fantastic on Blu ray I would say one of the best lookign Blu Ray I have seen.Be carefull when you try to put the discs back in the case very tight fit.
  4. CJPowers81
    CJPowers81
    Jun 26, 2007
    4,721
    Willenhall, West Midlands
    +799
    Try nail varnish remover, that's what I use for those stupid PS3 stickers you find on nearly every BR case.
  5. IPaintSara
    IPaintSara
    Jul 22, 2008
    302
    28
    +27
    I have the Australian issue so I'm not sure where the label you're referring to is. If its on a standard plastic case, not a cardboard slipcase, isopropyl alcohol should shift it. Available in small bottles at hifi shops or big bottles at chemists
  6. jon12355
    jon12355
    Jun 13, 2008
    781
    Wirral
    +64
    I always try to remove them from caes and they never come off properly. I remember reading in the tips in the back of nuts magazine to use talcum powder. Dont know how that would work though:D
  7. rebel_scum
    rebel_scum
    Jun 2, 2006
    11,460
    2
    +3,517
    You want to hear something annoying? There are later copies out there, without the blue sticker...
  8. dude-1981
    dude-1981
    Jan 2, 2009
    554
    28
    +30
    Mine didn't have a sticker. Ordered on Saturday night from Play. Came on Tuesday I think. :smashin:
  9. Garrett
    Garrett
    Apr 21, 2001
    44,839
    2
    167
    The best thief you'll never see.
    +9,081
    Thats what I use probably the gentlest of solvents, also I have used lighter fuel as well which also OK but a bit stonger.
    I just got a disc myself with oval slicker on the case, it came of ok with no residue just where its come of the plastic is raised :(
  10. rebel_scum
    rebel_scum
    Jun 2, 2006
    11,460
    2
    +3,517
    The UK case is cardboard, so using any liquid for removal is a tad iffy.
  11. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,146
    Bristol
    +9,892
    I always use the sticker that I just removed, if you gently dab it over the residue on the case it usually take it right off.
  12. rebel_scum
    rebel_scum
    Jun 2, 2006
    11,460
    2
    +3,517
    Agreed, but unlike the security labels on US discs, this is a single blue sticker on the front of the case, a cardboard case which has a suede effect to it. I just left mine alone, but I understand the OP's frustration.
  13. BLU-FAN IN BKK
    BLU-FAN IN BKK
    Feb 6, 2008
    159
    Opposite Pinewood Studios in Iver, Bucks
    +53
    Mine came without a label, thank god
  14. avtuner
    avtuner
    Mar 10, 2008
    299
    +10
    Had that exact same problem! Got half way and thought 'this aint working'!
    Took the rest of and tried to scrape the remaining glue residue off but it's bloody card! Anyway took it back to the store and exchanged for another copy without said sticker!
    I usually get some Meths or White spirit on stickers but for that I stayed well clear!
  15. CraigofScotland
    CraigofScotland
    Jan 13, 2009
    5,288
    +895
    AV Forums do not condone the use of crystals of any kind :lesson:
