Casette Data to PC
Discussion in 'General Chat' started by glenvern, Apr 17, 2005.
  1. glenvern
    glenvern
    How do I get Data from my casette player onto my PC.. Do I need special equipment?
    thanx..
  2. flash543
    flash543
    Nov 26, 2004
    1,743
    48
    Banbury
    +72
    Should be able to do reasonable job with a straightforward connection between the line output of the cassette player into the line input of your PC's sound card, or socket if sound provided by mainboard. The cable you will need will probably be a twin rca at the cassette end and a miniature jack at the PC end, although this of course depends on the equipment sockets.
    The sound card or motherboard will normally have come with a player/recorder program so use that to record the sound onto the PC hard drive. You can normally choose the input source from the program. If the cassette deck does not give sufficient output you could try using the mic input.
    You may have to experiment a bit to get decent recording but it can be done. Plenty more info on internet - do a search for cassette to PC.
    Good luck.
  3. glenvern
    glenvern
    Thanx Flash that worked ok
  4. flash543
    flash543
    Nov 26, 2004
    1,743
    48
    Banbury
    +72
    Good. You're welcome.
  5. mjn
    mjn
    May 24, 2001
    18,379
    Herts, England
    +5,464
    I thought he said "data".....not music.....
  6. flash543
    flash543
    Nov 26, 2004
    1,743
    48
    Banbury
    +72
    He did.
  7. Flimber
    Flimber
    Sep 22, 2002
    13,364
    Yorkshire
    +4,477
    I wasn't sure what the OP wanted either.
    But www.plusdeck.com looks good, in case anyone missed it last time it was mentioned here :)
    Mike.
