Case screws
Discussion in 'Digital TV & Video Players & Recorders' started by stevenmcg, Apr 6, 2002.
Tags:
  1. stevenmcg
    stevenmcg
    I have been unable to remove the top of the case of my Sky+ box. It has some sort of security screws fastening it. They are star shaped with a pin in the middle. Does anyone know the type of screwdriver I need to remove these screws?
    Steve McG.
  2. simon1
    simon1
    Jul 7, 2001
    918
    28
    Teesside
    +58
    They're called 'TORX'.
    There are two types available; normal, and security. You need the security type.
    The best option, and cheapest, is to buy the set of bits (the ones that fit in magnetic screwdrivers or drills).
    I bought this set a short while ago and found it to be invaluable.
    It is available from Maplin electronics, either in store or online.
    He is a link: http://www.maplin.co.uk/products/de...2495&modulecode=&moduleno=11520&manufacturer=
