case/remote for hd3???? do they exist
Discussion in 'Headphones, Earphones & Portable Music' started by jezmoz, Aug 5, 2005.
  1. jezmoz
    jezmoz
    looking for a case that will support it , the crappy pouch they give you is useless! Also where is the best and cheapest place for a compatible remote?
  2. tjdewalt
    tjdewalt
    May 17, 2005
    23
    4
    I bought the RM-MC40ELK remote for my HD3. It works great!!! In this way you can still have the lousy black pouch, since you will not have to remove the player. This one i got from www.bargaining4all.com
    I have also found some soft cylicone cases on e-bay. They are quite cheap, but the you'll have to pay 4 times the price for shipping...
  3. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    Silicon case about £6 (Ebay)
    RM-MC35ELK Remote about £30 (Ebay)
  4. drbober
    drbober
    Jul 28, 2005
    46
    I just tried a remote for a 6 year old CD walkman I have and it works fine. The display doesn't work but I'm not to bothered about that.
  5. tjdewalt
    tjdewalt
    May 17, 2005
    23
    4
    true, you can also use an old MD player remote. Remote works fine, but you have no display.
  6. Uridium
    Uridium
    Jan 29, 2005
    14,434
    +1,855
    MC35ELK works perfectly with the HD3, nice backlit LCD display on it as well
  7. alike
    alike
    if you still want a soft case then the ipod socks are cheap on ebay and fit fine
