Case For Fuji S602
Discussion in 'Photography Forums' started by kevenh, Jul 4, 2003.
  1. kevenh
    kevenh
    Jul 3, 2002
    342
    19
    Royal County Of Berks...
    Does anyone have some suggestions for me?
    I have a caseless Fuji S602 zoom.
    The Lowepro case recommended for that camera is the 40AW.
    That looks like it has space for camera + memory + batteries plus lenses!!
    I just need camera + memory + batteries.
    If I have to I'll go into a hi street store and check out some bags, but does anyone have a suggestion of a bag they've used with a Fuji S602 ?
    Ta
  2. pixie
    pixie
    Aug 30, 2002
    41
    Bristol
  3. kevenh
    kevenh
    Jul 3, 2002
    342
    19
    pixie,
    Thanks for the help.
    I gave up on buying online, and went to my local Jessops.
    The Lowepro 40AW didn't look as huge in real life as it did on the www!
    I bought that bag. £22.49, - even cheaper than I'd seen it online...
    Seems good quality, and has a waterproof cape that can be fitted if the weather turns a bit wet :)
    Oh! You gave up on your 602, but with a :( - It wasn't the cameras performance that let you down was it?
    It's a bit different to my old Fuji Finepix MX1400.
  4. pixie
    pixie
    Aug 30, 2002
    41
    Bristol
    hi kevenh,
    Glad you found a suitable bag - sounds a good one as it's waterproof!
    I bought a 602 back in December, but found that it had a CCD problem as every image had a mark in the same place (it looked like a burn) from a small cluster of dead pixels.
    I got a replacement camera sent to me, but this one had the same fault in a different area of the image, so I sent it back and got a refund. I haven't yet got around to buying another, as there are rumours of the 602 replacement! :)
    Pixie
  5. kevenh
    kevenh
    Jul 3, 2002
    342
    19
    Nasty! Err! Is this going to be easy to spot if a prob on mine?
    I read rumours of that on a US based camera forum, but dropping my old Fuji camera on to a hard floor kinda speeded up my replacement plans :) / :(
  6. pixie
    pixie
    Aug 30, 2002
    41
    Bristol
    Yes - it was easy to spot, especially looking at the image at 100%. Here's a link to cropped sections of images taken by each of the two cameras, I used these images when I emailled Fuji, and they confirmed it was a camera defect:
    http://www.turboslug.pwp.blueyonder.co.uk/extranet/camera/index.htm
    I could have kept the camera and edited them out, but I didn't really want to have to do this with every image I took!
    Great way to get a new camera! :D
  7. kevenh
    kevenh
    Jul 3, 2002
    342
    19
    Nasty! I'll have a closer look at my S602 results.
    Thanks a lot for checking this thread ;)
