Carter Projectors VPL700 4K 3D SMART
Idaryss
Hi All,
I would like your input for this projectors? Is it good? What is the average price?
Looking for a good projectors and somebody is selling this one for 800 CAD with a screen.
Could you please let me know?
Joe Fernand
Outstanding Member
Plenty of variations on that theme - someone somewhere going a long way to try and flood a range of poor quality kit into the market by claims huge MSRP’s.
Is it a brand you are familiar with or know anything about its supply and support in Canada?
What are you requirements for a projector - Inputs, throw distance, image size, light levels, run time etc
Joe
Idaryss
Thank you for your reply and the article.
I am looking for a projector for my basement. I dont know too much of projectors. My sofa is around 8/9 meters from my wall.
Its in basement so I dont have to much light in the basement but I would like something that support light as well to avoid any surprise.
Also I will use different input. I have a NAS (network attached storage) with PLEX. So I would like to be able to read movie from my NAS in my LAN.
And also to plug HDMI (but if its mounted in the ceiling I assume I need a HDMI switch....
Could you please advise?
Joe Fernand
Outstanding Member
Basement - sounds ideal.
Ambient light - is best avoided if you want a decent image.
Screen - do you plan to project on the wall or add a screen?
Room layout - can you put together a basic plan of the room and seating.
Seating - 9m is a fair distance, what size image are you thinking about?
Projector - will want to be ceiling mounted and many lower cost units will end up closer than 9m to the screen.
Sound - what are your plans?
Joe
Idaryss
Screen - I dont know what is the best? I think screen will be better no ?
Seating - the wall that can have the projection on is about 274 wide and 240 High
Room Layout - as mention the size of the wall, around 9 meters further there is my sofa put toward the other wall. I have a ceiling with lamp direclty in the ceiling so I think its easy to put cable through lamp hole.
Sound - I dont know something not too bad maybe a sound bar with a bass box. OR 4 little speaker at the ceiling + bass for the 5.1 suround.
jfinnie
Hi All,
This unit is undoubtedly a case of The White Van Speaker Scam. Total ripoff even at a seemingly low for the claimed spec $800. The spec is complete fiction and you've getting no more than $50 "worth" of gear here... and I use the term "worth" loosely, as while the parts have clearly non-zero cost the actual value to you of the system will be close to nothing.
Joe Fernand
Outstanding Member
Screen - no reason not to use a painted surface or create a DIY screen if you are working to a tight budget, some pics of the intended screen wall would help.
Seating - 9m is a long way away from a screen in a Residential System, you tend to loose the intimacy you want.
Sound - needs to have as much impact as the image and the front LCR speakers want to be at ear height not in the ceiling.
Minimise - less is more when you are on a budget, a decent stereo system is better than a poor 5.1 system.
jfinnie - less subtle than me, though spot on with your assessment :)
Joe
⭐ Philips OLED+908 TV preview + Avid Accent amplifier reviews + Hi-Fi & AV News
Back
