Carrying the legacy on.....
Discussion in 'Home Cinema Buying & Building' started by Russtar, Aug 16, 2004.
  1. Russtar
    Russtar
    All,
    Looking for advice/inspiration...just in the process of buying my first house and whilst the better half decides on the decor I've been left with the task of sorting the TV/Home Cinema out. I blame my father for giving me the home cinema bug.
    With a smallish living room I am seriously thinking about the Sony Dav-SC8 combined with the Sony KLV-23HR2S.
    I think that should fit in with the boss' designs for the house, meet my requirements and be within £1400-£1500 budget.
    That is however only my opinion and it perhaps could be swayed with some sound advice from you experts.
    Thanks in advance
  2. davet010
    davet010
    Jul 23, 2004
    385
    +10
    DAV-SC8 is about to be replaced, and there are also a number of posts on here with owners expressing concerns about the reliability of it. Best bet is probably to go and see your local dealer with the information of your room dimensions, then have a scout on the net for best prices.
