Carnival Silver Plus cables!
Discussion in 'Home Cinema Speakers' started by Mausse, Oct 31, 2005.
  1. Mausse
    Mausse
    I’m looking for (Budget) hi-end speakercables to fit my new speakersystem B&W MT-30 in combination with an Yamaha RX-V2600 av receiver. I wanted to buy the silver plated speakercables from the chord company “Carnival Silver Plus”. A friend of mine told me that it will sound too high in use with the satellietspeakers.
    Can someone give me some good advise which cable will fit my new system? :lease:
    Greetings Mausse
  2. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,132
    notts.
    +82
    Bog standard chord carnival looks like electric flex but sounds great with my m&ks should be fine with your speakers or any other quality copper cable, silver plated cable can make the highs grating at high volumes with some speakers..
  3. Mausse
    Mausse
    I'm not using this mt-30 set for high volume so i should be save with these silver cables
    THX for the reply
