Carlos Santana - Supernatural Live
Discussion in 'Movie Forum' started by Erling, Nov 24, 2004.
  1. Erling
    Erling
    Dec 4, 2002
    81
    Denmark
    Does anyone know if region 2 versions of the above title suffers from PAL speedup ?
    Cheers,
    Erling
  2. recruit
    recruit
    I have the Pal version what do you mean by Pal Speed up? as my copy plays fine!
    John
  3. Erling
    Erling
    Dec 4, 2002
    81
    Denmark
    I'm referring to the process by which film-sourced material originally shot w/24 fps are played back at 25 fps when transferred to PAL video.
    This gives an increase in speed of about 4%, which is quite audible for the sound.
    If the Santana concert is originally shot as video there shouldn't be any problems, but if the source was film, it is virtually certain to be speeded up. It may be done either with or without pitch correction, but it will still play faster. I wouldn't want that in a music disc, so if it's the case, I'd rather get the region 1 NTSC version, which will play at the correct speed (since NTSC uses 30 fps, film is transferred in a different way than with PAL - can't speed it up from 24 to 30 fps as that would be very noticeable)
    Cheers,
    Erling
  4. figrin_dan
    figrin_dan
    Jan 9, 2003
    1,993
    +136
    I don't think many concerts are recorded on film so you are pretty safe here. Although most live music is played faster than the studio version anyway, I wouldn't worry. (It sounds great in dts btw)
  5. purplefoot
    purplefoot
    Dec 15, 2002
    33
    11
    Faster (as in tempo), is not the same as a video transfer being sped up (causing an increase in tempo and pitch) which changes the key of the song, and is very noticable.
  6. recruit
    recruit
    I certainly have not noticed this and can assure you the R2 version sounds superb in DTS.
    John :)
  7. figrin_dan
    figrin_dan
    Jan 9, 2003
    1,993
    +136
    I can see what you mean. But in live music, unless all the musicians are perfectly in tune, it's not going to be a big deal.
  8. Erling
    Erling
    Dec 4, 2002
    81
    Denmark
    Thanks all for your input.
    Guess I should just go ahead and order the reg. 2 version I've found for about £ 9 :)
    Cheers,
    Erling
  9. recruit
    recruit
    Good price and a very good Concert :thumbsup:
    John
