car speakers
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by terrysearle, Aug 15, 2004.
  1. terrysearle
    terrysearle
    need some help chosing new speakers for my car have a peugeot 106 and need to change the door speakers as they arent really up to the job with the new 500w amp ive just fitted. i need speakers that will fit in the same door space so how much room do i have and any good models to get have £100 to spend was thinking alpine, sony dnt really know, just need ur help
    thanx
    terry
  2. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    Does you amp genuinely deliver 500w ?
  3. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    500w total music power?? = 125w per channel
    Look in the Infinity manual and look at seperates
  4. terrysearle
    terrysearle
    ive checked and its 130w per channel and i have only 13cm room in the front doors so any ideas on best speakers 4it?
  5. bazzason
    bazzason
    is it 130w RMS per channel? 2-channel or 4-channel?
    if its a 4-channel i suspect 130w is peak output, and to be fair for fronts 50w RMS is perfectly adequate. i am running an amp that delivers 60w RMS to my fronts with the gain on about 25% and it goes louder than i will ever need without distortion or clipping. if you want more, simply bridge the channels from 4 to 2.
    as for good fronts, there are loads of good 5.25" speakers out there - how much do you want to spend? £100? £200? more?
    [EDIT] just seen you want to spend £100 - these are two to consider:
    Phase Linear
    Alpine
    out of the two, the alpines deliver a better sound (i have heard both, and have the 6.5" versions myself).
    if you need a coaxial speaker rather than a component set, try either of these as a starting point:
    Alpine
    DLS
    the DLS are better quality speakers, but the alpines will deliver better bottom end frequencies.
