car radio
Discussion in 'Motoring' started by Mr Cat, Jul 5, 2005.
  1. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,215
    Weardale
    +57
    I'm thinking of getting a new car radio - my motor is a 10 year old peugeot 306xr...it already has a built in radio that is bigger than the standard sized radios... would this pose a problem..??
    cheers
  2. Solomon Grundy
    Solomon Grundy
    Nov 1, 2004
    13,453
    oop north.
    +3,023
    you should be able to buy a back plate which will have a slot in it to fit a normal shape stereo...
  3. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,215
    Weardale
    +57
    cheers - wasn't sure as the size of the built in radio (and it's cover) is about 3-4 times that of a normal radio...
  4. Solomon Grundy
    Solomon Grundy
    Nov 1, 2004
    13,453
    oop north.
    +3,023
    Try calling one of the car audio installers out of your local yellow pages...they should be able to at least point you in the right direction for free, they may even have just the item you need and a good deal on a head unit to go with it...
  5. shoehorn
    shoehorn
    Jul 2, 2003
    1,610
    The Garden of England
    +32
  6. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    As mentioned you'll need a fascia for the front and also some special tools to get the old radio out although if you're planning on getting a firm to swap them around then it shouldn't make any difference to you.
  7. michaelm
    michaelm
    Aug 13, 2001
    678
    Belfast
    Halfords do a blanking panel for the 306 for when you replace the original with a single height unit. Here it is.
    A quick check on the web should turn the same item up for a bit less.
  8. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,215
    Weardale
    +57
    yeah, was thinking of halfords as they do have some offers on and free fitting...
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    try sextons if you have one local moszt places will throw fitting in if you pay ticket price for the head unit
  10. stealther
    stealther
    Mar 24, 2002
    2,061
    Lichfield
    +93
    I cant begin to describe how easy it is to swap a headunit over.
    You will probably find it will be just the case of unplugging two connectors (ISO) and the arial and plugging them back into the new unit.
    You could save a packet by ordering one over the net this way.
  11. michaelm
    michaelm
    Aug 13, 2001
    678
    Belfast
    Agreed. I installed my Sony head unit in my old Escort and subsequently my Clio (our Almera Tino has a factory fitted system) and it was an absolute doddle.
  12. Bev478
    Bev478
    Apr 13, 2005
    140
    +8
    Before changing mine (Fiesta), did a lot of searching on the net - primarily for a new head unit - but that led to me realising that I would also need to buy a wiring harness, because Ford (amongst many) used a non-ISO standard wiring connection. A lot of car audio dealers, including Halfords, have a 'calculator' so you can find out what you need to fit a new head unit. I purchased a fascia plate & wiring harness online for the same price as just the fascia plate in Halfords :clap:
  13. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,368
    41
    Tunbridge Wells
    +12
    It can be difficult removing the old head unit though. But you are right, putting one in is easy.
