Car has IPod connector - I have an Archos
Kerr Avon
Hi there.
I just bought a car and it comes fitted with a connector that allows you to connect an MP3 player to the stereo.
However, the connector is IPod specific and I have an Archos AV580.
Is there any adaptor I can buy that will connect to this Ipod connector cable at one end and the Archos at the other (presumably the headphone socket)?
Cheers!
stevelup
This is more of a car specific question, not a cable specific one...
What car is it?
Steve
Kerr Avon
Thanks for the reply.
I have a Hyundai Coupe.
The cable is wired in and, I believe, connects into the back of the stereo where the CD multi-changer would plug in.
Anyway, the cable then comes up through the divider between the front seats and the connnector just, as far as I can tell (not having an IPod), plugs into the socket on the bottom of the Ipod.
I'd like a simple adaptor I can plug the car's cable into and then hook up to my Archos as I don't want to be ripping out the installed cable or anything drastic like that.
Cheers.
stevelup
I'm 99% sure that will only work with a real iPod connected to it.
It may be possible to remove the cable and fit a standard Aux input. I think you will need to ask on a Hyundai specific forum or perhaps your dealer.
I can tell you which pins on the iPod dock connector are the audio pins if you want to have a poke around and experiment?
Looking at the plug with the contacts at the bottom, pin 2 is ground, pin 3 is left and pin 4 is right.
Steve
Kerr Avon
You're probably right. I just thought that it should be possible, in theory at least, to have a little adaptor cable that I can plug into the Archos audio out and then connect to the plug on the car's cable.
Sort of like the adaptor cable I have that plugs into my PC's USB port on one end and a PS2 joypad plug on the other so I can use the joypad on my PC, if you see what I mean.
Of course, just cos it is possible in theory, doesn't mean there are any actually available to buy.
May have to buy an iPod, I guess...:rolleyes:
Podcast: Marantz SR7015 & NAD T 778 AVR + Mission LX2 MKII Speaker Reviews, AV & Film News and More
