Car Air-Conditioning
Discussion in 'Motoring' started by Geordie Jester, Jun 23, 2005.
  1. Geordie Jester
    Geordie Jester
    Oct 14, 2003
    1,437
    +156
    Just wondering if anyone out there knows how much it would roughly cost to service and regas a car's air con. Recently ive noticed it seems to be underperforming on a long journey. After a few hrs climate control almost packs in, closing the vents and stopping blowing cold air at all.
    Car is 4 yr old. Is that typical lifetime for gas ?
    Where can I get this done in the newcastle/Tyne and wear area ?
  2. Geordie Jester
    Geordie Jester
    Oct 14, 2003
    1,437
    +156
  3. Ethics Gradient
    Ethics Gradient
    Jul 29, 2003
    3,681
    aka Billy Science - Suni ojna Tas
    +430
    Re-gas ... probably £40 - £60
  4. GaryB
    GaryB
    Nov 12, 2002
    5,387
    St Albans
    +1,294
    Make sure they also check for leaks otherwise a regas will be a waste of time. What most decent aircon companies do is add dye to the gas and then let you run it for a day or two. The dye will show up any leaks, then they fix them and regas.
