Capturing using Pinnacle Studio 8
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by monkeyleader, Apr 18, 2003.
  1. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,621
    71
    Cambridge, UK
    +87
    Ive got a Sony DCR-IP7 and am using Pinnacle Studio 8 to capture and edit the video - When I go to capture its obviously picking up the camera as if I have it turned of it complains.
    I say capture and let it capture some of the tape - say 5 minutes - it then finishes but nothing seems to have been captured.
    The only thing I can see thats wrong is in capture source it says;
    DV CamCorder Pinnacle 1396
    Surley the IP7 should show up as a MicroMV recorder ?
    Any ideas - going out today to take some movies and would really love to start playing with the editing function.
    thanks,
    monkey
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    I don't know for sure if this is the problem but a lot of editing programmes are NOT compatible with MicroMV. I would suggest a visit to the pinnacle web site to check.
    Mark.
  3. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,621
    71
    Cambridge, UK
    +87
    Got it sorted - uninstalled the camera from device manager and this time it picked up the correct micromv format - now all i need is a larger, faster hdd :)
