Capturing Stills from Mini DV
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by hawksa, Aug 12, 2005.
  1. hawksa
    hawksa
    Jul 1, 2005
    44
    In other thread someone said that there is no image quality difference between a 1MP camcorder and a 3MP camcorder as PAL is a set resolution.
    If I upload video to my PC and then capture and print a still image, will I notice the quality then or do you only notice the difference when using the camcorder as a camera?
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,259
    Rainham Essex
    +2,403
    If you capture a still image from video recorded on a camcorder DV tape then you are only goiing to get the standard PAL resolution of 576 lines. If however you capture a still image to a memory card on the camcorder then the resolution will be as high as the CCD is capable of.
    Mark.
