capturing DVD material for editing
Discussion in 'Desktop & Laptop Computers Forum' started by MarkHB, Apr 25, 2005.
  1. MarkHB
    MarkHB
    hi guys - hope someone can help. I have recently had a bunch of old family cines transferred to DVD. Very pleased with the results and no problems viewing the material or copying the disks for other family members.Now I would like to edit the material, add titles etc.
    Unfortunately, however, the original movies were just captured back to back with no breaks - so each DVD contains a single title of some 3GB, which leaves me the problem of either splitting it in some way or of capturing it in one huge gulp. The Pinnacle AV/DV version 9 I am using doesn't want to know and gives me an 'insufficient memory' message (incorrectly) but their website notes this as a known problem trying to capture large amounts of data without (as yet) any solution .
    Any of you experts out there got a suggestion ? apologies if I haven't given you all the technical details you'd need - I'm way out of my depth here !
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I have very little experience of this but have used TMPGEnc DVD Author to do some simple menuing of old VHS->DVD rips. Not sure if it can handle VOBs (which I assume is what you have on your DVDs) but maybe worth looking at.
  3. DrPepper
    DrPepper
    Oct 2, 2001
    3,318
    Barking Essex
    +264
    TMPGEnc DVD Author does handles VOBs
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Thanks Doc .. it's some time since I used it and although I was fairly sure I'd used it on ripped VOBs I was certain so erred on the side of caution. :)
  5. MarkHB
    MarkHB
    great feedback, guys. Tried it last night and the TMP broke it into chapters and did the trick of establishing the menu I wanted with no problems at all. Still the same problem running the Pinnacle , which still sees it as a single Title and can't get past that to allow me to pick up individual chapters (in order to add scene titles, audio etc.), but i suspect that is just one of the shortcomings that makes some people dislike that software. I'm sure I can find another full function editor that's more friendly if I want to get really cute with the content, but for now your suggestions were spot on.
    many thanks !
  6. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Glad TMPGEnc worked for you, I was most impressed at how easy it was to do the little amount of fiddling I needed to do.
    I wonder if Pinnacle suffers from the old 2gb max. file size limit, wouldn't surprise me.
