Capturing DVD from PC internal DVD?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Lester's Cloud, Apr 3, 2002.
  1. Lester's Cloud
    Lester's Cloud
    Is there a way of capturing small sections, approx 5 - 10mins of DVD from an PC internal DVD?
    Want to use this for some visual effects at a live band gig.......
    I am very new to this so if there is a way please don't go too technical straight off the bat!
    Many thanks
    Lester
  2. JefUK
    JefUK
    Mar 31, 2002
    448
    28
    +54
    Copyright protection within commercial DVD's prevents this.
    There are very involved ways in which this can be done, however. To start see DVD Rip in http://www.vcdhelper.com/
  3. Lester's Cloud
    Lester's Cloud
    Thanks, yeah I have started to look at all the ripping software - does seem a lot of hassle just for a couple of images on stage...
    may still try it.........
    thanks though.
  4. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,634
    UK.
    +3,132
    I use smartripper. It's freeware and very good! Try a search and you should find it. I think my version is 2.25.
    Gary.
