capturing audio from stb
Discussion in 'Satellite TV, Sky TV & FreeSat' started by pat clancy, Mar 22, 2005.
  1. pat clancy
    pat clancy
    Sep 10, 2000
    1,805
    LONDON
    +29
    hi,i,m capturing audio from didital out on box to digital in on soundcard,it seem,s to be wav,i thoght freeview uses mp3 at 192kb,is it wav or what,and how can i check the bit rate,cheers,pat
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Not sure but I would have thought a digital broadcast would be using mpeg2 audio (mp2). Your capture device/software would then be grabbing the data stream and saving it in the format it is set up for be it wav, mp3 or other codec.
    Can't help with the desire to see the broadcast bitrates of the Freeview audio, I suppose it would be easier with a Freeview PC card rather than a external stb.
