Capturing analogue and DV
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by steev, Apr 11, 2003.
  1. steev
    steev
    Oct 22, 2001
    233
    16
    Beds, UK
    I already have a Pinnacle Studio DV card so I can edit from my DV camcorder, but now my Dad wants to get into this as well. He has a DV camera as well, but he also wants to transfer some stuff from VHS. He's aiming to transfer to SVCD as I have done.
    He's got an SVHS deck so he could capture S-Video. His camera does not have analogue inputs so he's going to need a capture card.
    I'm just wondering which is the best route. There's the Studio Deluxe for about £180 that does both formats. Alternatively he could get a Studio DV (£80) for the digital and for the analogue use a TV card (~£40) or get an AGP card with video in/out (£?). S-Video out may be useful if he wants to dump back to SVHS, but then that could be done from an SVCD in the VCR.
    The Deluxe is a nice integrated solution, but I'm interested in any opinions. Given that he's going to SVCD it doesn't have to be professional quality. Budget is preferably around £100, but he might go higher if there's real benefit.
    He's running an 800MHz Duron with 256MB on a PC Chips 810 board using the integrated sound and graphics. Nothing special, but I reckon it should be adequate. He does need to get a bigger HD, but that's a separate budget.
    Steve
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    One other option is to buy just a DV card and enable the DV input on the camcorder and then use that as an analogue to DV converter.
    The best method to make a cam DV-in enabled is to buy a widget.
    They can be bought from:
    www.smartdv.co.uk
    www.keene.co.uk
    & many others
    But check the make/model/serial number of the camcorder as not all can be made DV-in enabled.
    Mark.
  3. mij
    mij
    Jan 14, 2002
    3,442
    London
    +627
