capture with panasonic nv-ds27
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by binaki, Mar 6, 2003.
  1. binaki
    binaki
    Hi evrybody,
    i have a panasonic nv-ds27 camera and i want to capture videos to my pc for editing, i bought a tv card but i does not do what i planed, the quality and resolution is too bad.
    I don't know it's a firewire port on it (the cam) i have an iDV port, is that a firewire port?
    can i have a best resolution with firewire(more than 352*288)?
    thank you...
  2. m@rk
    m@rk
    Jan 3, 2002
    1,212
    83
    Lincolnshire
    +360
    Yes it is a firewire port
    Yes you can have better image quality using it
    Your camera *might* not have DV IN enabled though but if you do a search for Panatest on Google, you can change this.
  3. binaki
    binaki
    thank you Networkguy
    Now i must buy PCI firewire card and cable,
    please tell me :blush: if have to download any driver or software from panasonic website! Or it will be reconised with no problem ?
    I'm under XP Pro
  4. m@rk
    m@rk
    Jan 3, 2002
    1,212
    83
    Lincolnshire
    +360
    Well the cards are only £15 so not too bad
    You should not need any drivers though (other than what the firewire card needs and that will come with the card)
  5. binaki
    binaki
    Thank you ;)
    that was fast and intersting responses;)
  6. gazza100
    gazza100
    Be aware that if the serial number of your DS27 begins with a J , Panatest will not be able to enable the DV in. Mine does so I havent been able to get edited video back on to a DV tape
