Capture Sound Prob / Asus A7N8X
Discussion in 'Computer Components' started by Loafer316, Jul 13, 2003.
  1. Loafer316
    Loafer316
    Apr 8, 2003
    330
    Hi guys i trying to capture with various software using a PB-100 tv card with a signal via a old Nokia DTT box. Anyway with composite and phono sound out to the applications (showshifter etc) i get a distinct delay in sound...can i do anything to fix this?
    Also i Have a Asus A78Nx Deluxe M/b....which i thought had SPDIF input as well as using it as Output....the Nokia Box has Coaxial out so i connected it and have so far failed to get any sound even when selecting it in the Nvidia sound control software...:confused:
