Capture Sky+
Discussion in 'Desktop & Laptop Computers Forum' started by butlerpk, Jun 15, 2005.
  1. butlerpk
    butlerpk
    I have just got a tv card for my laptop. terratec cinergy 400 mobile.
    When i connect an aerial it works fine.
    im having trouble viewing sky from my sky+ box.
    i took the tv scart out and connected a scart from the sky box to the svideo conection on the tv card but nothing appeared
    i also svideo from sky box but still nothing appeared
    any ideas?
  2. DaveP
    DaveP
    Sky+ does not output s-video on the scart, neither do other sky boxes.
    Why didn't you use the s-video out on the sky+?
    Dave
  3. MikeFish
    MikeFish
    I think in that last line he said he also tried the S-video connection.
    Isn't there an option in the menu to switch between the 2 S-video outputs (or am I thinking of my DVD player?)
  4. DaveP
    DaveP
    when he said this:
    I assumed he had a normal sky box as well as the plus but you are probably correct. We'll probably never know!
    And I think you are thinking of your DVD player, there is only the option of RGB or PAL in the setup menu. (Do they call it PAL just to confuse people and make them call their premium rate lines, surely not!)
    Dave
