capture im moviemaker convert to dvd
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by Hbilly, May 4, 2005.
  1. Hbilly
    Hbilly
    Hope someone can help a beginner
    If I want to capture video from camcorder using moviemaker2, which setting should i use. will it always save as wmv?
    I then want to burn this onto DVD, can Nero 5.5 convert my file to MPEG2 or is there a free software that will do it?
  2. Brian110507
    Brian110507
    No you must capture in MovieMaker as DV-AVI - do not capture as .wmv or you will be very dissapointed with the results.
    Stay with DV-AVI through the editing and export of your video - then import the .avi into Nero for conversion and burning.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,109
    Rainham Essex
    +2,381
    IIRC Nero 5.5 will convert the AVI files to DVD compliant MPEG-2 files, but it is very slow and not very good quality. Nero 6 or later is much better, and the latest version allow you to create chapters. Even so I think Nero is not the best program to use. IMO you are better off with a dedicated DVD authoring program such as Ulead DVD Movie Factory that can be bought for around £30 or less, and the results will be much better.
    Mark.
