Capture cards
Discussion in 'Home Entertainment Computers' started by goat261, Feb 8, 2009.
  1. goat261
    goat261
    Nov 26, 2008
    1,182
    48
    +53
    hi all
    could anyone please tell me which card is the best to use for recording xbox 360 games in SD while playing In HD? (or is it even possible?)
  2. jameson_uk
    jameson_uk
    Dec 9, 2004
    3,707
    Birmingham
    +579
    I was going to say it is not possible but a quick search on google suggested it is now...
    I started looking for a component capture card to take an SD signal a year or two ago but nothing was available that really worked. I see now there are some HDMI capture cards but these are a couple of hundred quid.
    If you just want to capture you should be ok. Problem is gaming is not really possible through a capture card due to the lag. This means that even with a HDMI capture card you are still going to need to split the HDMI signal with one lot going to the card and out to your TV
  3. goat261
    goat261
    Nov 26, 2008
    1,182
    48
    +53
    o ok thanks for the info, sounds like its not really possible still then due to the lag it will cause :(
  4. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,595
    +920
    If you want to capture HD or SD component then the Hauppauge HD PVR is an option. It has an H264 hardware encoder - takes Component inputs and connected via USB2.
    It also has loop-through - so you can see your game-play with no lag, but record it at the same time.
  5. goat261
    goat261
    Nov 26, 2008
    1,182
    48
    +53
    thanks for info, ill take a look at that
