Capture cards Advice please
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by gjc-ortho, May 9, 2005.
  1. gjc-ortho
    gjc-ortho
    Feb 28, 2004
    1,491
    Bridgend
    +111
    Hi all,
    Basically after some advice regarding analogue capture. Got great software that I use for DV and my pc already has firewire. However, need to digitise a few bungy videos :smashin: .
    So, I need nothing more than a card with no software!
    Any suggestions greatly appreciated.
    Cheers all
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
  3. gjc-ortho
    gjc-ortho
    Feb 28, 2004
    1,491
    Bridgend
    +111
    Cheers Vonhosen but a little bit too steep to convert just a few videos.
    The idea of going to one of those places that do the converting for you has crossed my mind but I want the ability to edit the footage myself.
    Any more suggestions greatfully appreciated.
    Cheers all
  4. Brian110507
    Brian110507
    Use you DV camcorder - easy if it has AV-in (NOT the same as DV-in) many allow 'pass-through' - that is conversion from AV-in to DV-out without even having a tape in the camera. then use the same connection and software as you use for digital capture.
  5. gjc-ortho
    gjc-ortho
    Feb 28, 2004
    1,491
    Bridgend
    +111
    No AV in mate, which is rather annoying as this was my original plan!
    Thanks for all the help and please keep the suggestions flowing.
  6. Brian110507
    Brian110507
  7. gjc-ortho
    gjc-ortho
    Feb 28, 2004
    1,491
    Bridgend
    +111
    Cheers all.
    I've decided to go down the canopus 55 route.
    Thanks for all the help. :thumbsup:
