Capture Card (S-Video) For HTPC.
Discussion in 'Desktop & Laptop Computers Forum' started by Nick_W, Jun 20, 2003.
  1. Nick_W
    Nick_W
    Jun 20, 2003
    206
    28
    +28
    I seem to be going round in circles trying to find the last component of my HTPC!
    I want a card that will capture from S-Video using stereo audio. It does not need to have a TV tuner (but it's OK if it does), and it does not need to capture DV stuff.
    It needs to be PCI, and price is not really an issue (well, I'd like it to be under £300). It must work with ShowShifter.
    Please can anyone provide any suggestions?
    Regards,
    Nick.
  2. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    try the Packard Bell PC TV 100, basically a re-badged lifeview 2000. £29.99 from PCworld (so a long way under £300!).
    Owain
  3. Nick_W
    Nick_W
    Jun 20, 2003
    206
    28
    +28
    It's not stereo.
    Regards,
    Nick.
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    I think you normally handle the audio capture through the soundcard.
  5. Nick_W
    Nick_W
    Jun 20, 2003
    206
    28
    +28
    Then there are lipsync issues, no?
    Regards,
    Nick.
  6. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    Possibly depends on the latency of your kit. Don't know any other way of doing it though. Not any that are less susceptable to lipsync issues.
  7. Nick_W
    Nick_W
    Jun 20, 2003
    206
    28
    +28
    I was under the impression that most capture cards had audio in?
    Regards,
    Nick.
  8. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    Some have RF inputs which give the potential to decode nicam in some instances but I'm pretty sure even these require an additional internal connection to the soundcard. I've seen one or two which have stereo phono inputs but again extra connection to soundcard required. The USB units may work differently.
  9. Nick_W
    Nick_W
    Jun 20, 2003
    206
    28
    +28
    Ah! I understand now. So although they have sound inputs, I still need to connect them to my card (Audigy2) to actually record it :)
    Thanks for clearing that up.
    Regards,
    Nick.
  10. gab2001uk
    gab2001uk
    Dec 3, 2002
    236
    +5
    Vidac VMagic from www.vidac.de
    Does not work with Showshifter AFAIK, but captures s-video and stereo audio direct to MPEG1 / 2 in real time. The tuner version does not work properly in the UK (No sound). Has a timer / scheduler for recording and time shifting. Ideal for plugging Sky into it.
    MPEG files can be burned straight to VCD SVCD or DVD
  11. dgc
    dgc
    May 1, 2003
    216
    My HTPC has the VIDEOh! PCI capture card from adaptec
    ... http://www.adaptec-uk.com/
    cost under £100 and does a good job. Not had any lip sync issues.
    Would not advise use of the bundled MyDVD software for capture.
    Instead download the Movie Mill software from Snazzi. It works with the Adaptec card,does a better job and is more flexible.
