Capture audio or movie scene from DVD
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by thanphis, Jun 17, 2005.
  1. thanphis
    thanphis
    Dec 16, 2004
    7
    Hi!
    I' d like to record / capture songs, dialoge or movie scenes from DVD to my PC.
    Is it possible to do it?
    When I encrypt DVD, it has VOB files that Adobe Premiere doesn't recognize and I can't open audio files too.
    I need help...
    Thank you!
  2. Brian110507
    Brian110507
    If it is a DVD you created (and therefore has no copyright protection) then copy the .vob files to your hard drive and rename them as .mpg ie #####.vob becomes #####.mpg. these will contain video and audio together - there are no seperate audio files on a video DVD
    You should then be able to import them to Premier and edit as you wish.
  3. thanphis
    thanphis
    Dec 16, 2004
    7
    O.K. Thank you!!
    I'll try it...
  4. phosphorus
    phosphorus
    im in confusion! ive done this process before (changing the .vob file to a .mpg) than importing it into premier and has worked fine. it has been a few months since i have done this, now when i import the .mpg file premier errors and shuts the program down!! ive been using pro 1.5 and ive installed my old version 6.5 and it still does it!! help pls!!!
