Cantons and watt question
Discussion in 'Home Cinema Speakers' started by docjan_uk, Aug 24, 2004.
  1. docjan_uk
    docjan_uk
    Aug 20, 2004
    82
    Hi guys, pretty much chosen the HT setup and got a couple of questions.
    The Receiver amp is going to be a Denon 1705 which outputs 75 watts per channel.
    Now, after reading around to find the best set of speakers under £500 the Canton CD1's seem to stand out here... at around £420 and better than Kef 1005's and perhaps around 2005 levels etc.
    I havent heard them but after reading some reviews they also rate them highly.... so were thinking of just dropping the hammer on that.
    Questions I guess... anyone else got anything to say on these speakers?
    Also, the ratings are 45/80 watt on the speakers.. I guess this means that it takes an average of 80 watts to move the speaker through its full range of motion at the highest volume (and 45 at the lowest?).. if so can the 75 watt receiver suffice?
    The way I see it, at all normal volumes it should be fine and quality will degrade and the speakers will only be in danger at the highest volumes (say around 90% of maximum or higher... the system is never going to be heard at such high volumes).
    Anyone got any advise on if that 90% figure is around right or on 80 watt speakers on a 75 watt system?
    Anyone got advice on this?
    Also this is where were thinking of ordering from:
    http://www.hifi4less.com/Canton_CD_1_Home_Theatre_5_1_Speaker_System.htm
    Anyone got a cheaper place or know if this place is OK? some people get stuff perhaps £150 cheaper from europe but Id rather not get stuff from abroad with no recourse or guarantee on product or delivery on time etc.
  2. mevetts
    mevetts
    Oct 31, 2003
    439
    Not sure about the whole matching speakers to receiver issue. However, I am going to be getting the Canton CD1s and pairing them with the Yamaha RX-V650 receiver. Advice from Yamaha says that they will work fine together.
    If you can, buy the Cantons from Germany. Much cheaper! Here are some useful links -
    http://www.avforums.com/forums/showthread.php?t=134073
    http://www.mediaran.de
    Cheers,
    Mark.
  3. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Forget it... :cool:
    The 1804 outputs something like 6x40w and the 2803 6x50w...
    Only 2 channel claimed output is reliable or even exceded, like most AVReceivers.
    There are a few exceptions, the Marantz SR4500 or SR5400 can output real 6x80w for instance...
    But with satellite speakers that may no be a problem...
  4. docjan_uk
    docjan_uk
    Aug 20, 2004
    82
    Indeed... decided to change tack and go with the 1905 which rates at I read somewhere as 115 DIN (what does that mean... something to do with rating when you lower the ohms figure?) but other places as 80.
    These are small satellites I guess... ?
  5. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Your going to buy them without listening to them????
    I admire bravery!
    FALP I salute you! :beer:
  6. docjan_uk
    docjan_uk
    Aug 20, 2004
    82
    hehe, wellllll... Ive heard the Kef's and I havent heard a bad thing about these speakers and all signs point to being better... and given that current sound is being output by a 10 year old sony TV about to blow up it cant be that bad... and for around 260 pounds on a 500 pound set of speakers you cant really go wrong... can you? ;)
  7. Marmite
    Marmite
    Jul 16, 2004
    197
    +5
    Are they really as good as the eggs? Im really put off by the shape of the eggs (egg shaped, surprisingly! - but bigger than i thought they might be) so was looking at these as a potential alternative, but im seriously doubting how they can be this good considering the tiny size and the pretty small price.
    Falp, are you saying not to worry about what the amp outputs are when pairing with these speakers? Sorry to hijack the thread a bit :blush:
  8. docjan_uk
    docjan_uk
    Aug 20, 2004
    82
    Well from what Ive read here and in a review or two.. they outperform the 1005's.. as for the 2005's it would seem that these kinda level peg, a little better in certain fields and not in others... HOWEVER this is only what Ive read and not from experience.
    For the price though they do look like the best at that level for sure.
  9. tommypeters
    tommypeters
    Aug 16, 2004
    7
    Go to http://www.hififabrik.de and get the Canton 25 XL 5.1 system for less than 300 pounds. That's a 6-700 pound system that beats what you're talking about here...
  10. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    What? How's that? :confused:
  11. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    :blush: Sorry Falp, Wrong person. I'll read who posts what more carefully next time.... :laugh:
