Canton with Mission
Discussion in 'Home Cinema Speakers' started by Stellavision, Aug 25, 2005.
  1. Stellavision
    Stellavision
    Apr 7, 2003
    2,375
    Southsea, UK
    +101
    I am looking into changing my M7D's for Canton CD 310 F's.
    However, seeing as my primary listening is movies the conclusion I think I am coming to is that I may be better with my bioploe M7D's for the diffusion. I have been searching on the whole bipole, dipole and monopole thing and it seems many people prefer monopole / direct radiating for the surround back. So I may even try the Canton's in the middle of my back wall for the 7.1 surround back channels.
    My questions are:
    a) would this work OK seeing as my sofa is right up against the back wall?
    b) could I be jeapordising the quality of the surround soundfield and steering by having two brands of speakers?
    c) would I be better sticking with 4 missions or 4 cantons?
    :confused:
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    I'd say that the positioning of the 4 rears is probably more important than the brand of tweeter - with films anyway. Sofa right up against the wall? I would try 7.1 with the speakers you already have - then see if the tonall differences are noticible.
    You may find that 5.1 is more than enough.
  3. Stellavision
    Stellavision
    Apr 7, 2003
    2,375
    Southsea, UK
    +101
    Sorry if In wasn't clear. I have been running 7.1 with my existing speakers for quite a while and I am wondering if I may benefit from changing the combination.
    I am happy with the sound, but I'm just in search of perfection.:)
  4. Stellavision
    Stellavision
    Apr 7, 2003
    2,375
    Southsea, UK
    +101
    One of the reasons I am thinking of direct radiating all round is so I can get the right surround further back. If you look at the picture I am posting you can see that the lounge door cuts a corner off the room making it impossible to get the two L&R surrounds opposite each other. With bipoles, dipoles and tripoles one of the speakers drivers will bounce off the adjacent wall next to the door if too close.
  5. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    Mmm, yes, I see your problem. :(
    I reckon that you are making the most of your current setup issues. A direct radiating speaker will cut down (a bit) on wall-rebounded sound on the right rear, but then you'll have to be even more careful with how you set the delay left vs right. :rolleyes:
    Stick with the Missions - the Cantons are probably only going to be a sideways step and you'll probably have to butcher your lovely walls as well. :thumbsdow
    Spend the difference on beer and dvd's. :clap:
  6. Stellavision
    Stellavision
    Apr 7, 2003
    2,375
    Southsea, UK
    +101
    Like the advice, thanks, especially the beer bit.:D
