Canton or MS Premieres?
Discussion in 'Home Cinema Speakers' started by Superdan, Oct 31, 2004.
  1. Superdan
    Superdan
    Oct 31, 2004
    27
    Woo hoo..first post!
    After many hours looking I've decided either hte Canton CD-1 imported from Germany or the MS Premieres... what do you guys think?
  2. cool hand luke
    cool hand luke
    Not that its much help but like you im still undecided between the Cantons or Shorts and its hard to argue with the price you can get the Cantons for from Germany.
    And now i notice the Warfdale Diamonds have been voted best speaker in one of the magazines.Good luck with your decision.
  3. Mango Bob
    Mango Bob
    Jan 12, 2004
    513
    16
    London
    I'm in the same boat, torn between the cantons and the premiere's. Does anyone know somewhere in the south-east where I can audition them?
    Which of the two is likely to sound best with music or would I be better off going for a set with full-size fronts?
    Just found this thread:
    http://www.avforums.com/forums/showthread.php?t=159635&highlight=canton+music
    Unfortunately adding MS914s is a bit beyond budget so still searching for a musical set of speakers for under £400!
  4. andhoey
    andhoey
    Jul 23, 2004
    80
    9
    how would the cantons compare to the tannoy fx5.1s?
  5. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,229
    2
    +3,718
    The premieres are no slouch musically and do have the advantage of being completely compatible with the full size Avant loudspeakers if you wanted to upgrade later on. The 904 is especially suitable for this.
  6. Superdan
    Superdan
    Oct 31, 2004
    27
    For me its 100% movies...got other equipment for sounds. Come on guys help me out here, I've got upgrade-itis very bad! First it was a new telly, now speakers....if im lucky it will be new dvd and amp before the wife notices!!!
  7. Superdan
    Superdan
    Oct 31, 2004
    27
    Hey Bob and Luke, I've taken the plunge and ordered the Premieres...Got them off all the w's hificonfidential.co.uk, £249.99. Cheapest I found them, I'll report back when they get here! The dude said it would be Thursday so heres hoping.
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  9. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Ive just had a look at the set your talking about and they are just the standard premeires and you then have to add £20 for postage so £270 in the end. The subwoofer that is with them (308) is inferior to the sub with the Premiere plus system (309) otherwise its a very good system :D
  10. Superdan
    Superdan
    Oct 31, 2004
    27
    Premieres arrived today...very nice. My old sub had only a phono input, but this has a left and right input...my amp also has just a phono output... do i need a phono to stereo or ill m old phono to phono produce the same result?
  11. saturday
    saturday
    Feb 9, 2003
    Sussex
    You don't need to connect both (they're on the same internal circuit) so single phono is fine.
    When I bought mine about 18 months ago, I recall a thread which talked about this with someone fron MS. You might find it with a search?
