Canton CD2.22
Discussion in 'Home Cinema Speakers' started by nheather, Apr 25, 2005.
  1. nheather
    nheather
    Oct 6, 2004
    15,149
    Horsham, West Sussex
    +4,352
    I've seen many references to the Canton CD2.22
    Does this actually exist as a set or do you just buy the invidual components ... I think they are
    CD100 x2
    CD50 x1
    CD10 x2
    AS22
    Cheers,
    Nigel
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    correct CD2.22 is reffered to in the canton brochure (was) but never on the website it is 2x CD100 2 x CD10 1 x CD50 and 1 x AS22C
  3. richard76
    richard76
    The CD100 floor standing units are not suitable due to my living room size...are there any substitutes available ?
  4. nheather
    nheather
    Oct 6, 2004
    15,149
    +4,352
    What about using CD50s as the fronts and wall mounting them - this is what I intend to do.
    I suspect the CD100s may be better musically though. Although they have the same number of speakers they are described as 2x woofer, 2x midrange and 1 x tweeter - the CD50 is stated as 4x woofer and 1x tweeter.
    Is this just marketing or does the CD100 specifically have mid-range drivers and cross-over unit ?
    The CD100 is also a bass-reflex design whereas the CD50 is a closed design.
    Cheers,
    Nigel
