Canton CD100
Discussion in 'Home Cinema Speakers' started by Genesis, Mar 12, 2005.
  1. Genesis
    Genesis
    Aug 11, 2004
    196
    +3
    How musical are the Canton CD100 (with a sub ) in stereo mode. I ask this as these speakers are high on my AV system list. I recently heard them with a velodyne sub and they sounded quite harsh in stereo mode, this my have been due to the setup of the sub.I also listened to the CD300 and some Cabasse Ki's. To me the Cabasse speakers sounded warmer and more full bodied than the canton's. I am hoping this was just due to the way the system was setup as cosmetically the Canton's are just sensational.
  2. johnnycab
    johnnycab
    Jan 26, 2005
    84
    Genesis - I am hopefully going to buy a Velodyne sub in a few hours...and my CD100's arrived yesterday. I ran them in all day, and put a variety of stuff through it i.e. speech, classical/instrumental, hip-hop, dance etc. They are extremely versatile, and cope with everything without falling over. BTW - I heard them with classical music being played through them at the Bristol show.
    However, so far I find they are not as bass heavy as my old Tannoy's - which is ok by me, as I will be using them(CD100) as rear speakers. They are good all-rounders and produce mid-range quite accurately, and it is just a case of running them in and tweaking the settings on the amp.
    To summarise, it would depend on what you will be using these speakers for. If it is predominantly bass-heavy music - then in my opinion, you should be looking at something else.
  3. Jake James
    Jake James
    Do not forget, you need to run these speakers in for a minimum of 150hrs, they will totally change. Initially they can be a bit on the bright side, but once they are run in they become much smoother and the bass will deepen, coupled with a good subwoofer the 2.1 stereo sound can be absolutely amazing if you have the right setup / cables/ electronics etc.
    If you are considering the CD100's then checkout the Canton subs as well as they are perfectly matched
    check out the 'Canton in the UK' thread :thumbsup:
    regards
    JJ
  4. simonrad
    simonrad
    Feb 9, 2005
    35
    Manchester
    Hi JJ
    can you give me a bit of advice, I demo'd the CD1 and wanted to see what changes I could make to the set up to improve for 2 channel music, I was told that CD50 has the same components as CD100, is this the case? if so can CD50's be used for Front L/R & Ctre? will this be an improvement for music (and movies generally), will these 2 work well with two CD10's at the rear or should all 5 be the same, how would a CD50 based system compare with the Movie 22-x II?
    thanks
  5. Jake James
    Jake James
    Dear Simonrad
    You are correct, the CD50 has all the same components as the CD100, I think the crossover is slightly different because the CD50 is a closed system and the CD100 is Bass reflex system (ported) the CD50 goes down to 60Hz and the CD100 goes down to 50Hz due to it utilizing the full length of the cabinet and the fact that it is ported.
    A great setup would be
    5 x CD50
    or 3 x CD50 + 2 CD10
    If you need further advice, PM me
    regards
    JJ
  6. Jake James
    Jake James
    sorry
    the above solutions would be better than a Movie 22 XII
    regards
    JJ
  7. patr1ck
    patr1ck
    Jun 29, 2002
    253
    Manchester
    +26
    Jake,
    The Canton web site is a bit misleading.
    It says:
    CD50 4 x 80mm woofer (base?) and 1 x 15mm tweeter
    CD100 2 x 80mm woofer, 2 x 80mm mid-range, 1 x 15mm tweeter
    Is the CD50 spec wrong?
    Pat
  8. simonrad
    simonrad
    Feb 9, 2005
    35
    Manchester
    thanks JJ, not many shops have these in stock to do a demo so I am trying to make a decision based on the CD1 demo, what would the advantages be of three CD50's at the front compared to CD10's also, what would the cost be?
    thanks Simonrad
  9. Jake James
    Jake James
    Dear Pat
    You are right the canton website is a bit misleading.
    Both the CD50 & CD100 are set up in the same way. 4x 3" drive units + 1x 15mm tweeter. All 4 Drive units act as woofers, but 2 of these 4 act as woofer and midrange. The CD100 can go lower than the CD50 because it uses the full length of the cabinet and is also ported.
    _____________________________
    Dear Simonrad
    If you had 3 CD50's across the front, this would give you a fuller sound with better integration into the sub, due to the sub not having to come up as high to meet the satellites.
    CD50 £88 each inc VAT & Free delivery within the UK
    as always, any questions, let me know
    regards
    JJ
  10. simonrad
    simonrad
    Feb 9, 2005
    35
    Manchester
    thanks JJ, time to have a think
  11. Sheltie
    Sheltie
    Nov 22, 2004
    56
    9
    JJ,
    can you explain the factors which would decide whether you would go for a front facing or downfiring sub.
    I am considering 3 CD50 for fronts and CD10's for rears, but am unsure what sub would best compliment.
    I will mostly be using for dvd movies, but also for music/concert dvd's.
  12. Jake James
    Jake James
    Dear Sheltie
    I wrote a message in the 'Canton in the UK' thread, I think it is msg 10. you may find that usefull.
    If you want a system that is more AV based I would go for a down firer like the Canton ASD220SC, ASD250SC or Karat AS200SC.
    If you are after a more musical approach then forward firing
    This is only a rule of thumb it depends on the size of room, flooring, flat or detached house etc
    If you want to PM me with your details, feel free
    regards
    JJ
