Canton cd1 best partner for £225?
Discussion in 'AV Receivers & Amplifiers' started by spiderman1, Jun 7, 2005.
  1. spiderman1
    spiderman1
    Very tight budget to buy a receiver because the plastic has been very much used :rolleyes: and I need advised on what is the best I can get for that money. Canton cd1 speakers to go with the receiver. Thanks :hiya:
  2. dirge
    dirge
    Apr 21, 2005
    201
    +6
    Sure someone can recommend better but I got the Yammaha 450 thats advertised on superfi at the moment, and am very happy with it. Build quality is fantastic and has everything I need on it. If you state what you're using it for I'm sure the other people round here can help you better with your decision mind :)
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    add Pio 402 to that list
  4. spiderman1
    spiderman1
    Thank you lads,
    It would be 50/50 for music and films. I don't know wich one is better but the yami looks stronger. And the price is within my budget. Any other ideas? :thumbsup:
  5. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    I know this is a little above your price but the NEWYamaha 557 is available.
    Also the Denon 1905
  6. dirge
    dirge
    Apr 21, 2005
    201
    +6
    Check on superfi they have the products but also have a view to the rear of the amp showing what connections they provide. It all depends on what you need like I said. My Yammy has component connections while Horney's suggestion has scart. Check what your current gear has and what you want to connect with etc.
    I got the Yammy as I'm looking into projectors and plasma's to source and control from the unit by component not scart.
