Cant watch scary movie
Discussion in 'Movie Forum' started by Puzzled, Dec 14, 2000.
  1. Puzzled
    Puzzled
    I have just recieved my copy of Scary Movie and when I play it all I get is the FBI warning playing, I have left it over 20 mins and it is still playing. I then tried it on my PC and it worked fine. I have a Thomson 3300DTH DVD player that has a paragon upgrade and it is set manually to region 1.
    Has anyone else had any problems with the film, mabye its lucky that I am getting a new Sony 735 dvd player for christmas then.
    James
  2. Guest
    James,
    Can't really help only to say that I've got a Pioneer and Toshiba DVD and both play my copy???? If you get the FBI warning, sounds like it's past the stage where the new coding cuts in? Try it in a friends player but to me it sounds like a knackered disc?
  3. Puzzled
    Puzzled
    Hi Mr Bond
    Thanks, but I managed to get it to play, I noticed that the FBI warning was playing a track as the timer on my dvd player was going up and it didn't say menu like it normally does. So I left if for over 20 mins and then when I looked back at it, it had finally gone to the menu. Whats with a 20+ min fbi warning doing on a disc. My PC just skips the track after a few seconds and then carries on which I guess is what is suppose to happen.
    Least I can watch the movie now but I have to wait ages to do it. Weird.
    Thanks anyway
    James.
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,606
    Somewhere in South Yorkshire
    +6,149
    Just watched mine last night. My old Pioneer 505 (HongKong spec) plays it without problems, BUT every time the disc requires the player to find a different title, menu, etc.... (automatically or when I select something) the "search" seems to take a little longer than I'm used to. I guess there IS something a little odd about how this disc has been coded.
    Excellent film, and a very good transfer.
  5. Guest
    I too had the same problem.
    It loaaded, got to the menus and was fine but when i started the film it went back to the load up screen of my dvd player (eclipse)with a little world symbol i then pressed a few buttons and managed to get into the film, after that it was fine and played all the special features correctly.
    I t played first time on my mates laptop (compaq pressario).
    Very odd. [​IMG]
    Maybe i`ll go to the movies.....by myself!!!
