Cant wait any longer: Tosh PF2 or Pany PD30 ?
Discussion in 'General TV Discussions Forum' started by bboy-mass, Sep 27, 2003.
  1. bboy-mass
    bboy-mass
    Dec 31, 2002
    338
    Birmingham
    +12
    I know you guys are well clued up on ya televisions, but I cant stand another day of reading your reports.
    Simple question: Tosh or Pany?
    Why? I have had a Sony Trinmiton Wide since 1998, so am I going to see the difference.
    My hardware:
    Arcam DV88 DVD player
    Tag AV32R Processor
    Roxan 5 chan power amp
    B&W CDM7 SE front and back
    Kef 200C centre speaker.
    I know my home cinema guys, but Im not that hot of TV.
    What would you go for.
    Peace.
    Mass
    Birmingham
  2. Graham27
    Graham27
    Sep 26, 2003
    3,125
    St. Helier, Jersey
    +970
    Same question !
    I went for the PF2 but had 3 dodgy ones so I'm currently back to the old 4:3 Sanyo :(
    So do I try the Tosh again or go for the PD30 ?
    I had decided on the PD but then I came across this site... :suicide:
    I've read all that I could find via search but I'm just looking for opinions.
    Thanks in advance !
  3. bazzae123
    bazzae123
    Mar 10, 2002
    315
    16
    I assume you guys have read this
    http://www.avforums.com/forums/showthread.php?s=&threadid=95484
    but at the end of the day your the one who has to live with it. Go down to your local shop and have a good long look at all the options. Try and find a shop that does a 7 day trial, I know Hughes does this and at one stage had agreed for me to try 3 different models before I had to decide but I went for the PD30 in the end. In the end if you look for perfection in a TV you'll go mad.
    Best of luck in your quest, its not easy:suicide:
    Bazza
