Can't upload images back into Casio once downloaded to PC
B
BigLad
Hi folks,
Forgive my newbiness but I have searched google for ages and cannot find an answer. Once I download an image from my Casio Exilim Z-55 using 'Photoloader' that came with the camera I am unable to reload the images into the camera. Nor can I load an image from an e-mail somebody sent me so that I can show the image to others in my camera.
I have tried simply dropping and dragging the image file onto the SD card in my laptops card reader but when I display the images in camera the new additions aren't displayed, despite being there when I pop the card back in to the laptop to check.
Any ideas folks?
Many thanks.
Newby.
RBZ5416
You need to replicate the file structure the camera is expecting to see. Take a couple of pics & then look at the card in the card reader. You will find a folder called DCIM & maybe a subfolder below that. Copy the images you wish to view there.
If may be that when your software downloads images it deletes these folders.
B
BigLad
Okay thank you. I'll give that a try and report back.
Cheers Crocodile.
