cant stream files from laptop to xbox
Discussion in 'Xbox Forums' started by nufc_fan, Dec 23, 2006.
  1. nufc_fan
    nufc_fan
    Jun 25, 2006
    235
    i have a laptop connected to my 360 using a bridged wireless connection via ethernet, xbox live works great but i cant stream any files from the laptop to it.
    Im using an ethernet connection, i have media player 11, i tried installing the software from xbox.com/pcsetup, but it wont run.
    If i go to media player - library - media sharing, there is no xbox
  2. MyBigToe
    MyBigToe
    Oct 15, 2006
    572
    +9
    how do you mean the program wont run?
  3. nufc_fan
    nufc_fan
    Jun 25, 2006
    235
    the programme windows media content, i downloaded and extracted it, i try to open the programme and nothing happens!
    is this because of media player 11
  4. MyBigToe
    MyBigToe
    Oct 15, 2006
    572
    +9
    does the Windows Media Connect program run (the icon should be in the bottom right hand corners)?
    If so, set up the folders you want to share, and then choose the videos to run from the xbox, not from the PC
    I dont know if i misunderstood or anything though.. ive already had a couple of beers :p
  5. nufc_fan
    nufc_fan
    Jun 25, 2006
    235
    no it wont run
  6. nufc_fan
    nufc_fan
    Jun 25, 2006
    235
    no one know what to do??
