Cant seem to use my DVD/AMP via digital cable :(
Discussion in 'Blu-ray & DVD Players & Recorders' started by thefunkygibbon, Dec 10, 2002.
  1. thefunkygibbon
    thefunkygibbon
    Jul 23, 2002
    1,238
    +37
    Got a Tosh 220E DVD player and a Yamaha HTIB45 setup.
    Just got a PS2 so thinking i will use that via the optical cable into my amp, then use a digi coax cable from the DVD. theorhetically should be all fine.
    works fine with optical cable but absolutly nothing with the digi cable.
  2. Alsproject
    Alsproject
    Nov 12, 2002
    181
    +8
    Are the digital inputs on the amp reassignable?
    On my Yamaha (different model), I had to reassign the co-ax input from CD to DVD before it worked, otherwise, you will need to switch it to the correct input that is associated with the co-ax input.
    Also, have you activated the digital outputs on the DVD player?
    Alan
  3. thefunkygibbon
    thefunkygibbon
    Jul 23, 2002
    1,238
    +37
  4. Alsproject
    Alsproject
    Nov 12, 2002
    181
    +8
    Ok, I have just downloaded the manual for your amp.
    Does the sound work when you switch the amp to CD? If it does then you can either use it like that or you can start to reassign the digital connections.
    You can only have one digital connection to each input (eg, co-ax to DVD, optical to CD) otherwise it might confuse the amp or disable one of the inputs.
    On item 7 of the setup menu, you can assign the digital inputs. Just change the co-ax (D) to DVD and the optical (C) to CD or any other input that is available (apart from DVD)
  5. thefunkygibbon
    thefunkygibbon
    Jul 23, 2002
    1,238
    +37
    if i reassign the coax to dvd then i presume that the optical would have to be assigned as CD. if that is the case will it not work with DTS/DD5.1 on the PS2 when i connect that through the optical?
  6. Alsproject
    Alsproject
    Nov 12, 2002
    181
    +8
    Nope, this is not the case as the input selection (ie CD, DVD, VCR, etc) are just labels so you know what component you are using.
    The decoders will decode DD 5.1/DTS no matter what input you assign to it as long as you turn the decoding on.
    Alan
  7. thefunkygibbon
    thefunkygibbon
    Jul 23, 2002
    1,238
    +37
    brilliant... i'll take a looksy tonight then... many thanks Alan :D
  8. Alsproject
    Alsproject
    Nov 12, 2002
    181
    +8
    You are very welcome mate :)
