Cant run my DVD's - fdshow?
Discussion in 'Desktop & Laptop Computers Forum' started by Ice Rich, Mar 20, 2006.
  1. Ice Rich
    Ice Rich
    Mar 4, 2006
    24
    Hello,
    I recently installed fdsho and theatertek. the dvd plays but the screen is black, no picture. This also happens with WMP.
    Ive disabled all the codecs apart from RAW -was that right?
  2. dan1979
    dan1979
    Sep 16, 2004
    3,539
    83
    +218
    ffdshow doesn't affect dvd played in WMP so it's something else, changed the primary display or anything?
  3. mikeaitch
    mikeaitch
    Apr 21, 2001
    1,608
    Stoke
    +56
    Try setting the RAW codec to YV12
    Then set the output section also to YV12
    disable ffdshow for now, and use the latest TT
    HTH
  4. Ice Rich
    Ice Rich
    Mar 4, 2006
    24
    Still no Luck :(
    Please post any sugestions.
  5. dannyg81
    dannyg81
    Nov 23, 2005
    382
    +9
    Are you using the fully paid for and legit version of TheaterTek? If it's the trial version then the DVD codecs it uses have expired and your s**t outta luck. In my experience the only time Theatertek displays a blank screen is when the trial has expired after a week.... and if you're using a downloaded and cracked version, then they probably ran out a long time ago.
    This could possibly affect WMP because natively it can't playback dvd's, it uses external DVD/MPE2 codecs, so it's probably trying to use Theaterteks and running into the same problem.
  6. Ice Rich
    Ice Rich
    Mar 4, 2006
    24
    dannyg81> I think you are exactly right, looks like my version has expired :)
  7. dannyg81
    dannyg81
    Nov 23, 2005
    382
    +9
    No problem.... same thing happened to me when using the trial! :D
