Cant rip T3!
Discussion in 'Desktop & Laptop Computers Forum' started by rhinoman, Nov 17, 2003.
  1. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    Tried to use DVD shrink to rip this film (which I bought) to my hard drive but its says its copy protected. Any way round it?
    Its the region 3 version if that makes a difference.
  2. Gazzz
    Gazzz
    If your DVD ROM drive is region locked you can get this error.
    Also try copying the VIDEO_TS folder to your hard drive, then use something like IfoEdit to hack the IFO files and remove any region codes, RCE protection etc.
  3. Bursar
    Bursar
    Jun 29, 2003
    2,405
    63
    Cambridge
    +215
    I've successfully ripped the disc using DVD-Shrink without any problem.
    The drive isn't region free, but I did have DVD Region-Free running at the time. Don't know if this made any difference though.
  4. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    I've got region killer running and dvd shrink says its an encrypted file.
    Just tried it with smart ripper and thats says its needs a key to unencrypt it:confused:
  5. Bursar
    Bursar
    Jun 29, 2003
    2,405
    63
    Cambridge
    +215
    Strange, as I didn't have any problems. Have you tried playing the DVD first, then exiting the player, and then starting DVD Shrink?
    Other option is to download a fresh copy of DVD Shrink and see if that helps.
  6. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
  7. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    dvd decrypter is the kiddy, mine is sat on the HDD in it's full glory, just need a jpeg to show on my HTPC and we are getting WAF
