Can't record coded dvd/tapes or none PAL tapes on the LG DR4810
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by reevestim7, Sep 26, 2004.
  1. reevestim7
    reevestim7
    Hi, can u help.
    First of all i've been given the multi-region code breaker for the above dvd player which i bought on Saturday. You have to open the disc tray and then press: 0000000 (thats 7 times). This also works with the LG RH4810V.
    However do u know of a hack which will allow me to copy copy prevented videos/dvd's and, i've forgotten the American signal name, it's not PAL like ours it's..........anyway I've tried to copy some Pal and (NTLS??) signal tapes, using a slave player (video for tape and dvd player for disc) into the LG through it's scart connectionat the rear with a view of putting my old video tapes onto disc. However, when i press record the screen displays a message stating unable to record. Could u help?
    Cheers< Phil :lease:
