Can't put movies on my psp.
Discussion in 'Playstation Forums' started by chrisafc, May 3, 2005.
  1. chrisafc
    chrisafc
    Mar 20, 2005
    212
    I read every step by step guide and still cant do it, little help please?
  2. aligebes
    aligebes
    Jan 2, 2004
    233
    Edinburgh, Scotland
    +3
    What error do you actually get? Can you please be more specific with your problem.
    If you do a search here there is alot of info regarding movies on your PSP, Think there is a step by step guide somewhere as well.
    You need to create 2 folders on your PSP 1st. I will post later when I have more time(I'm at work at the moment)
  3. aidey6
    aidey6
    Dec 12, 2003
    416
    2
    Warrington
    +67
  4. Rob20
    Rob20
    Jul 3, 2004
    3,107
    +665
    I know how to put videos onto PSP using PSP Video 9, but I have no idea where to find software to rip dvds or even software to rip cds into MP3 format. Any suggestions?
  5. paulfoley
    paulfoley
    Sep 17, 2003
    3,569
    Hants
    +119
    Look for DVD Decrypter or DVD Shrink, both free & easily found via Google.
    Its worth it believe me !
    :thumbsup:
  6. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    35,216
    Bristol
    +8,541
    All you need to get your DVDs onto your PSP is DVD Decrypter, PSP Video 9 and a large memory stick.
    You use DVD Decrypter to rip the film from the DVD to a single .vob file, then you load the .vob file into PSP Video 9, select the settings and once done you will have a file ready to be transfered to the memory stick.
  7. chrisafc
    chrisafc
    Mar 20, 2005
    212
    i got the converter, 3gp i think it is, i just dont know what to do with the folders.
  8. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    35,216
    Bristol
    +8,541
    I would suggest upgrading to PSP Video 9 as when you start it up and connect your PSP it will create the folders you need automatically.
  9. chrisafc
    chrisafc
    Mar 20, 2005
    212
    k thanx
  10. Rob20
    Rob20
    Jul 3, 2004
    3,107
    +665
    Found this brilliantly simple explanation for how to get dvds onto PSP mem sticks using dvd decrypter and Video 9. Is a step by step video guide.
    Click here!
    When you get your mem stick you should format the card before doing anything else. This creates the neccesary photo/music etc files. However, for videos you need to create a folder specifically, (though don't put it in the PSP folder). Next to the PSP folder, create a new folder and title it 'MP_ROOT'. Inside this folder, create a 2nd folder and title that '100MNV01'. This is where you'll transfer your videos to.
  11. chrisafc
    chrisafc
    Mar 20, 2005
    212
    When i try to convert some videos using PSP Video 9, i get an error message reading Transcode Canceled.
    Any reasons why?
  12. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    35,216
    Bristol
    +8,541
    It happens when the file you are trying to convert isnt supported like the newer .mov files, everytime I try to convert the Star Wars Episode 3 Quicktime trailer I get that 'Transcode Cancelled' message.
  13. chrisafc
    chrisafc
    Mar 20, 2005
    212
    do i need to convert thoughs videos then before i convert them on psp video 9?
  14. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    35,216
    Bristol
    +8,541
    That is what I have done.
  15. CENSORED
    CENSORED
    What's the best profile to use with a 512mb memory stick?
  16. dr_loss
    dr_loss
    yeah some movie formats dont work so well with the image converter or video9 programs
    try using pc based format converters to switch them to avi or mpeg first and then run them through PSPVideo9
    my site has a few more alternativwes, although it is a little out of date now
    ________________________________
    www.ballofodd.co.uk - everything PSP
  17. aidey6
    aidey6
    Dec 12, 2003
    416
    2
    Warrington
    +67
    click on the main guide :thumbsup:
    hope this helps you amongst others....
