Can't plug two video cables into DVD teaser
Discussion in 'Cables & Switches' started by David_of_Surrey, Jan 22, 2005.
  1. David_of_Surrey
    David_of_Surrey
    Oct 13, 2004
    200
    +6
    Hi guys,
    I wonder if anyone has a solution to this, I have a JVC XV-N 412 DVD player and have component video cables running from it to an AE700 projector, this all works fine.
    I want to be able to plug a scart cable into the DVD and connect to the TV at the same time as having the component leads connected, the manual says you can only have one set of cables connected to the DVD, I did try ignoring this but all that happens is that the signal gets interupted every two seconds or so and the projector screen goes blank (so the manual was right!!!)
    I could go from the DVD to the projector to the receiver via Component but our TV doesnt support component and the Receiver doesnt convert component to any other form.
    Does any one have any good ideas?? cheaper the better :)
    Thanks Dave
  2. David_of_Surrey
    David_of_Surrey
    Oct 13, 2004
    200
    +6
    OK I've been of investigating......
    would this cable - (Profigold PGV372 component to scart) work?
    http://www.tvcables.co.uk/cgi-bin/tvcables/PGV372.html
    I could then have the one set of component leads from DVD to the receiver and then connect a set of compent leads from receiver to projector and the component to scart lead from receiver to the TV (TV will accept RGB)
    Dave
  3. frankie13
    frankie13
    May 14, 2001
    683
    england
    +8
    hi m8 did u find picture stutter on this player when played through your projector
  4. David_of_Surrey
    David_of_Surrey
    Oct 13, 2004
    200
    +6
    No it seems fine on mine, what are you seeing?
  5. frankie13
    frankie13
    May 14, 2001
    683
    england
    +8
    on certain dvd copies i see picture judder ohers ok maybe it does not like datasafe 1s
