pault2007
I was wondering if someone could help.
We've recently had Sky HD installed and lately, the volume buttons on our Sky HD remote (revision 9F) haven't been working with our LG 32LD450 TV.
The programme up and down buttons work fine but when I press the volume buttons, nothing happens and the light doesn't even come on on the Sky box.
The standby button works on the remote, though.
I've tried putting in the codes suggested on Sky's web site (using the code finder wizard) and I've also tried the '990' blink-back method by counting the number of led blinks after pressing 1-4 and entering the resulting number.
The code entry method I've been using is:
- Press TV button with remote aimed away from box
- Aimed at box, press Select and red button together
- Remote led blinks twice
- Enter 4 digit code
- Press Select to store
- Press Sky button to test
Is this the correct method?
Is there anything else I can try - apart from buying a new remote?
Mum says that the volume on the Sky remote was working fine until we pressed standby on the LG's remote and shouldn't have done. Could this have had an impact on things?
Thanks in advance.
Paul
Thanks in advance.
Paul
