Can't make optical connection work on LG Tv
marby72
I'm looking for troubleshooting advice on connecting an LG Smart TV to a Vizio Soundbar with an optical cable. I changed the setting on the LG TV (photo attached) and tried various ideas for getting sound out. It is not muted and the soundbar works fine with bluetooth. I can see a red light at the end of the cable on both ends whatever that means. I believe the hardware connection is correct. The tv is model 50LF6090. Any additional troubleshooting advice would be appreciated. Is there a method to test the optical output port on the tv? Thanks.
JayCee
Unplug/switch off the TV and soundbar at the power socket for a fews mins then power up and try it.
From what I remember, the optical output was permanently 'live' on those old NetCast OS televisions...
Inferno
Have you tried selecting it to LG Sound Sync and trying that?
