Cant load my driver for Sony camera
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Scania94, Sep 12, 2003.
  1. Scania94
    Scania94
    I recently bought a Sony Trv 22 video camera but my computer will not accept the driver so cannot use the Imagemixer program supplied with it.
    Has anyone any suggestions, my computer is from Time and is only one year old with sufficient memory etc...
  2. snelly
    snelly
    May 24, 2002
    227
    Berkshire
    +3
    well,
    what Operating System is it? XP? Are you running the latest service packs etc? That out of the way what error do you get and which driver are you trying to install? There could be drivers for stills capture over USB, Firewire capture cards etc...
    Tim
  3. Scania94
    Scania94
    thanks for coming back to me Tim. I am running Window ME which I continually update. The disc I have is from Imagemixer for Sony which includes Sony usb driver and on the disc is written spvd-010 usb driver. On running I am instructed to click on handycam, one loaded I am to remove the disc and reboot. I try to remove the disc but am met with a window telling me I am trying to remove disc and the computer shuts down before I am able to remove the disc. On restarting nothing is in the Device manager where it should be according to the manual. is this any help?
  4. devastator
    devastator
    May 15, 2002
    1,561
    48
    +49
    I have just got the TRV 22, couldn't get the USB to work at first. Read the manual :) and it tells you to enable the USB streaming 1st on the camcorder.
    Installed the drivers.
    Rebooted.
    Connected the Camcorder to USB cable.. Machine picked it up.
    Loaded the Sony software, it picked up the Camcorder..
    ALL WORKING :) ..... not sure if you have the same issue.
  5. Scania94
    Scania94
    Thanks for that, I will give it a try and get back to you. I did manage to get the photo side of it working. Jeff
  6. Scania94
    Scania94
    Devastator, I tried what you suggested and have got it all running now, many thanks to you and tim for answering my query now all I have to do is practice etc.. Thanks again
    Jeff
