Can't import AVCHD clips longer than 5 mins in FCP
liparus
I'm running Final Cut Pro 6.0.6 on an iMac 24 with my HMC152 (Aus version of HMC150).
My one and only problem is I get the dreaded red exclamation point when trying to import any clips longer than 5 mins.
I changed the prefs from ProRes to AIC with no luck and I have 2TB of disk space.
Any suggestions?
:nono:
innerscape
Established Member
It's a bit long winded, but try this.
As imovie is full AVCHD compatible, you can import your clips to imovie, and save as FCP XML file via the share button.
🎬 The Top 20 Most Anticipated Movies of 2024
Back
