YorkshireBloke
Hi all,
New member here, sorry for the long post but I’m trying to give a clear explanation of my problem.
First a bit about myself, I’ll keep it relevant to my question re. having trouble hearing dialogue on movies at home.
I’ve spent 40 years in IT. I’m used to high levels of technical details, but also well aware that tech products can be very easy to sell but don’t always live up to the sales speak. I know they constantly want you to upgrade in the hope that things will improve
My hearing is good. My equipment is :
Samsung Q90T tv
Samsung HW-Q70T soundbar with sub woofer.
Dialogue on movies is very muffly, while the sound effects and music soundtrack are clear and too loud. It’s the same with or without the soundbar. If I turn up the volume to hear the dialogue clearly, the effects and music are deafening. I’ve done some research and can see this is a common problem. I’ve tried Standard / Surround and Adaptive modes, basically any combination of TV and Soundbar settings that I understand. I’ve drawn the line at having a home theatre room built to the correct dimensions and filling it with a full home theatre surround system
Here’s my current work around : I watch movies when I go to bed, on my old LG non-smart, non 4k tv which has 2 wonderful features, a Clear Voice setting and a 3.5mm headphones jack. I’m using a ROKU for streaming. I can clearly hear dialogue without the headphones, and if I want a good surround sound experience also with clear dialogue, I plug in the headphones. I can also control headphones volume easily with the tv remote.
How can I achieve clear dialogue with my Samsung setup ? I don’t mind removing the soundbar if I have to, or using headphones.
Using headphones is my current research. If the Samsung TV had a 3.5mm headphone jack, that would be problem solved. I don’t fancy Bluetooth headphones, I’ve never tried them due to lag / latency issues. I know “the internet” says lag has been improved with Bluetooth 5.0, but unless you can convince me, I’m gonna pass on that.
I’m thinking of trying a DAC using optical out from my Samsung tv, and my wired headphones.
Could anyone recommend one please ? I’m not sure why some DACs have a volume knob, surely if I set the sound output to optical on my tv, I can control the volume from my tv remote ?
Do some DACs have a volume control to fix signal to noise ratios, eg in the past I’ve had headphones with an in built volume control that were very hissy, to fix this I turned up the tv volume and turned down the volume on the headphones.
Thanks.
Samsung Q90T tv
Thanks.
